Go Back   RIDGID Plumbing Forum, Woodworking Forum, Power Tool Forum > Pipe Related Trades > Drain Cleaning Discussion
k3800 guide tube/K60 carrier/question
Old 03-16-2008, 08:53 PM
gear junkie's Avatar
gear junkie gear junkie no ha iniciado sesión
Occupation: Navy Seabee/Plumber/HVAC Tech
Years Experience: enough to be dangerous
Nominated 26 Times in 12 Posts
Nominated Thread of the Week Award(s): 4
Default k3800 guide tube/K60 carrier/question
Here's the pics I promised
1. complete assembly
2. no hub from rip off central-fergusons
3. hose from plumbing section of HD
4. some widget from the electrical section at HD. To make this work, wrap electrical tape around the hose to build up O.D.
5. got some 1/2", 3/4" and 1" pex to go around the handle of my cable carrier. So much more comfortable than the thin handle. Wrap electrical tape around the 1/2" and 1". There's no tolerance between the 1" and 3/4" so no tape is needed on the 3/4".
This was originally about 6 ft but is too hard to control so I shortened it down to 4 ft.
Can I use a section of my 5/8 section as a trap leader for my 1/2" IC cable?
ID:	2888   Click image for larger version
ID:	2889   Click image for larger version
ID:	2890   Click image for larger version
ID:	2891   Click image for larger version
Old 03-16-2008, 09:16 PM
ToUtahNow's Avatar
ToUtahNow ToUtahNow no ha iniciado sesión
Occupation: Plumbing Contractor/Consultant
Years Experience: 37
Nominated 85 Times in 18 Posts
Nominated Thread of the Week Award(s): 10
Default Re: k3800 guide tube/K60 carrier/question
Nice job Ben I will be interested to see how the PVC hose holds up. Please make a review after you've used it for a while.
I never lost a cent on the jobs I didn't get!
  #3
Old 03-16-2008, 09:17 PM
Doubt you'll ever get a review Mark. Since getting the 60, I've used the 3800 maybe 4 times.
Old 03-16-2008, 09:22 PM
ToUtahNow's Avatar
Quote:
LOL_Well I like your carrier for the basket of the K-60 as well. Is the 1/2" PEX a tight fit or does it allow the handle to rotate?
Old 03-16-2008, 09:33 PM
It does allow the carrier to rotate inside the pipe handle. If you use the 5/8" carrier, omit the 1" pex. Not enough room in there and you'll scrape knuckes. Don't forget about my trap leader question.
Old 03-16-2008, 09:43 PM
ToUtahNow's Avatar
I've never owned a K-3800 but in a pinch I did use 5/8" as a leader on my 3/8" in an adapter for my K-50 once. It's a long story but it has to do with the day KFC lost an entire batch of grease from their frier down a 2" floor sink. The open wind 5/8" leader was used to collect the grease out of the P-trap.
  #7
Old 03-17-2008, 05:01 AM
PLUMBER RICK's Avatar
PLUMBER RICK PLUMBER RICK no ha iniciado sesión
Occupation: PLUMBING CONTRACTOR
Years Experience: PLUMBERS HELPER 1975-80/FULL TIME PLUMBER SINCE 1981
Nominated 128 Times in 45 Posts
Nominated Thread of the Week Award(s): 21
ben not sure if the auto feed horn is the same size as the 7500 feeder, but i have a great set up that is much simpler and less sticky than the pvc hose you have.
i'll look at it with you at the round up.
carrier or question, guide, k3800, tube or k60
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
