Go Back   RIDGID Plumbing Forum, Woodworking Forum, Power Tool Forum > Pipe Related Trades > Drain Cleaning Discussion
"baby wipes" out sump pump
Old 11-03-2009, 09:12 AM
PLUMBER RICK's Avatar
PLUMBER RICK PLUMBER RICK no ha iniciado sesión
Occupation: PLUMBING CONTRACTOR
Years Experience: PLUMBERS HELPER 1975-80/FULL TIME PLUMBER SINCE 1981
Nominated 172 Times in 68 Posts
Nominated Thread of the Week Award(s): 27
Default "baby wipes" out sump pump
made you look
had a customer call, complains of a smell in their guest house. it's only 2 years old so i ask a few questions. turns out that the rear guest house is on a sewer ejector pump. i asked them to see if the water is overflowing the outside pit. no, but it's close to the top
check the outlet. gfi is dead run an extension cord to see if it will pump out. nope, dead.
ok, i'll bring a new pump with me.
so i check the illegal sump pit. it's not even vented. had a hard time pulling the pump as the 3 abs pipes are blocking the path of the pump to be removed. i finally forced it out of the pit.
turned it over and started to pull out a pile of baby wipes all jammed around the pump impeller.
managed to get the pump running as it blew the gfi and saved the pumps thermal switch.
put it all back together and tested it out. ok
showed the owner the pile and she was not surprised. i spoke to their 6 year old son and he spilled the beans like balloon boy but told me they're in the basement in plastic bags.
zoller 2'' ejector pump. after i pulled the wipes out
this is the pile i pulled from inside the pump impeller. those are 10'' #430 channelocks
a real tight fit getting the pump in and out. 3'' toilet discharge and 2 discharge into pit. 2'' out to sewer. no vent and they tried to glue, silicone the pipe penetrations. a real mess.
ID:	8771   Click image for larger version
ID:	8772   Click image for larger version
The Following 2 Users Say Thank You to PLUMBER RICK For This Useful Post:
Gene Bickford (11-03-2009), Vince the Plumber (11-07-2009)
Old 11-03-2009, 09:30 AM
Swade Plumbing's Avatar
Swade Plumbing Swade Plumbing no ha iniciado sesión
Occupation: Complete Plumbing Service Since 1905
Nominated 14 Times in 4 Posts
Default Re: "baby wipes" out sump pump
Yikes! What a mess! That pit looks like one of the "what's wrong with this picture" games from magazines.
At least you were able to salvage the pump!
Nice job Plumber Rick
The Following User Says Thank You to Swade Plumbing For This Useful Post:
PLUMBER RICK (11-03-2009)
Old 11-03-2009, 09:31 AM
DanLawrence's Avatar
DanLawrence DanLawrence no ha iniciado sesión
Occupation: Pipe Flow Specialist (FPS)
Years Experience: 9
Nominated 53 Times in 9 Posts
Nominated Thread of the Week Award(s): 7
So the channel locks where in the pit?
The Following User Says Thank You to DanLawrence For This Useful Post:
Old 11-03-2009, 09:39 AM
Jerad's Avatar
Jerad Jerad no ha iniciado sesión
Nominated 3 Times in 2 Posts
Nominated Thread of the Week Award(s): 1
i have the same channel locks.
hold on......
i just checked those are my channel locks!
the only dumb question is the one that is not asked!
The Following 2 Users Say Thank You to Jerad For This Useful Post:
Bob D. (11-03-2009), Vince the Plumber (11-07-2009)
Old 11-03-2009, 09:44 AM
DUNBAR PLUMBING's Avatar
DUNBAR PLUMBING DUNBAR PLUMBING no ha iniciado sesión
Occupation: -Master Plumber/Entrepreneur
Years Experience: 21+
Nominated 89 Times in 33 Posts
Nominated Thread of the Week Award(s): 13
I use those foam pads all the time as well. I need to cut the design off that meshes them together because it looks like I'm dropping foam peanuts.
I worked for a guy that changed his tune immediately when he went from angry his sewage ejector stopped working and I was last to touch it, to "Oh nice plumber I didn't know oh can I get you a pop/something to eat/back massage from my wife" kinda way.
That pump I installed was now jammed up with at least 70 of those wipes.
Now I'm charging, a lot. << Emergency call that started out with attitude? I'm chargin'.
I was nice, considerate though; I had him flush that line out leading to the pit about 40 times which discovered the rest of those wipes. If I would of zipped my mouth shut it would of been a repeat call.
He dumped his fiance' almost 4 months later after that. He's kept his current companion now for 5 years. Good job! and no pump failures either!
The Following User Says Thank You to DUNBAR PLUMBING For This Useful Post:
Old 11-03-2009, 02:11 PM
jhplumbing's Avatar
jhplumbing jhplumbing no ha iniciado sesión
Occupation: Licensed Plumber/ Business Owner
Years Experience: 10
Nominated 2 Times in 2 Posts
I bet you did not even use rubber gloves.
  #7
Old 11-03-2009, 06:05 PM
Gene Bickford's Avatar
Gene Bickford Gene Bickford no ha iniciado sesión
Occupation: Drain Tech
Nominated 39 Times in 13 Posts
Nominated Thread of the Week Award(s): 4
YUM< YUM< YUM, looks like a big ol' pot o' poop soup
  #8
Old 11-03-2009, 08:11 PM
toolaholic toolaholic no ha iniciado sesión
Occupation: gen.contr.
Years Experience: 46
Nominated 12 Times in 7 Posts
Nominated Thread of the Week Award(s): 3
Cool Re: "baby wipes" out sump pump
Rick , I hope You charged well.That's the extreme!
The more You explain it, the more I don't understand it .
Mark Twain
  #9
Old 11-03-2009, 09:47 PM
my billing is based on the time i worked on it. so the bill is the same weather i am digging, working with the poo or thinking
last week while i was on the plane, i was watching t.v and still getting paid for travel
The Following User Says Thank You to PLUMBER RICK For This Useful Post:
toolaholic (11-03-2009)
  #10
Old 11-03-2009, 09:51 PM
JCsPlumbing's Avatar
JCsPlumbing JCsPlumbing está en línea
Occupation: Nunya
Nominated 67 Times in 34 Posts
Nominated Thread of the Week Award(s): 9
Had the same thing happen with "feminine items".
Also found a 4' blacksnake while working on it.
TACOS!
baby wipes, pump, sump
