Go Back   RIDGID Plumbing Forum, Woodworking Forum, Power Tool Forum > Pipe Related Trades > SeeSnake Diagnostics Equipment
Tool Box Monitor
Old 11-20-2009, 08:55 PM
SewerRatz's Avatar
SewerRatz SewerRatz está en línea
Occupation: Illinois Plumber
Years Experience: 20+
Nominated 35 Times in 10 Posts
Nominated Thread of the Week Award(s): 7
Send a message via Yahoo to SewerRatz
Default Tool Box Monitor
I was wondering if there is instruction manual , parts break down, and a schematic drawing for the tool box monitor available?
There are these blue wires that lead up to the CRT just under the pivot point its heat shrink and I notice it turns the unit on and off indeterminately. Is it a micro switch for when the CRT is folded down it turns off the unit? or is it some sort of fusible link?
The CRT cracked a few years back, and I never replaced it now that you all came out with the RCA interconnect cable for the MicroExplorer, I want to revive this guy since it will power the SeeSnake nicely and has a Video out. I will just use the MicroExplorer as my monitor.
Old 11-21-2009, 09:05 AM
PLUMBER RICK's Avatar
PLUMBER RICK PLUMBER RICK no ha iniciado sesión
Occupation: PLUMBING CONTRACTOR
Years Experience: PLUMBERS HELPER 1975-80/FULL TIME PLUMBER SINCE 1981
Nominated 172 Times in 68 Posts
Nominated Thread of the Week Award(s): 27
Default Re: Tool Box Monitor
micro switch when folded closed.
i might have a parts break down in my older manuals.
rick,
  #3
Old 11-21-2009, 10:29 PM
SewerRatz's Avatar
I found the instruction manual on Ridgid's website. http://www.ridgid.com/ASSETS/0220954...onitor_Man.pdf
It does not answer one of my questions what is the auxiliary connector for? Did they make anything to plug into it?
Also found the parts break down too. http://www.ridgid.com/ASSETS/EDA7054...Monitor_PL.pdf
Old 11-22-2009, 10:20 AM
Ace Sewer Ace Sewer no ha iniciado sesión
Occupation: Drain Cleaner
Years Experience: 6
Nominated 37 Times in 11 Posts
Nominated Thread of the Week Award(s): 6
I've not ever seen that monitor. kind of looks like a sweet little setup. Mine are the viedo toolcases, similar but bigger with a vcr in them.
I've never seen anything to plug into the aux connector. mine have din plug outs for vid and sound which I use. In the toolcase monitor manual there is a pinout for the aux connector on pg 15, which may apply to your box as well.
http://www.ridgid.com/ASSETS/788B9E6...l_Case_Man.pdf
The Following User Says Thank You to Ace Sewer For This Useful Post:
SewerRatz (11-22-2009)
Old 12-03-2009, 06:44 PM
irguy irguy no ha iniciado sesión
Occupation: Instructional design
Years Experience: 16
Quote:
No, there was never an accessory made for the Aux connector.
Guy
The Following User Says Thank You to irguy For This Useful Post:
SewerRatz (12-03-2009)
Old 12-03-2009, 06:59 PM
SewerRatz's Avatar
Quote:
Guy
Hi there Guy,
Do you know what the pin out is for that Aux connector is and what kind of plans they had for it? ie. a keyboard / character generator?
box, monitor
