Stacked Dado on TS2412
Old 03-28-2001, 08:47 PM
dennism dennism no ha iniciado sesión
When I use a stacked dado on my TS2412, there is play in one of the chipper blades located above the space between the threads and shoulder of the arbor. This creates a small groove at the bottom of the dado. Pushing up slighly on the bottom of this specific chipper while tightening mostly remedies this problem. However it makes for timely set-up and needs to be compensated for every time I loosen the arbor (adding/removing spacers to achieve the desired width). Is there an arbor that I can retrofit to my saw that will allow the dado to work better?
[This message has been edited by dennism (edited 03-29-2001).]
Old 03-29-2001, 09:46 AM
Dennis,
There is an arbor that you can get that will remedy that problem. Some of the earlier arbors had rolled threads instead of cut threads, causing a slight diameter change from the shoulder to the threads. Call 1-800-4RIDGID and talk to Customer Service, and they will send you a complete arbor housing assembly at no charge. The arbor itself is a press fit, so it is necessary to include the complete housing. It’s not hard to change and instructions are included with the housing.
Old 04-02-2001, 05:22 PM
How often do you see this kind of service?
Old 04-17-2001, 12:11 AM
hamhand hamhand no ha iniciado sesión
Would this apply to a 2424? I bought a Freud Super Dado and it seems to be a piece of junk at $160.00! My old Sears wobble dado cuts as good a dado. I was going to write a nasty letter to Freud but when I saw this post I wonder if the saw is at fault. How does one check this out? Any help is much appreciated as I am really disappointed in the dado head.
Old 04-17-2001, 11:46 AM
Ham, call 1-800-4RIDGID.
Old 04-18-2001, 12:16 AM
Wink
I received my replacement arbor assembly from Ridgid at no charge. I installed it (although it was missing instalation instructions), and now my stacked dado works MUCH better (and saves a lot of setup time), It took me about 45 min to figure out and execute the switch, but it was time well spent. Ridgid sent out the part and I received it within 5 business days (Thanks Ridgid). If your replacment is missing the instructions email me @ dnamaw@aros.net and I can give you some basic beta to get through it.
Old 08-07-2001, 11:44 AM
TStin TStin no ha iniciado sesión
Jake, would I be left out, having the Craftsman mod. #315.228310? I called Ridgid cust. service and they were unaware of the problem.
Travis
Old 08-08-2001, 09:41 AM
Travis,
Let me check with one of our old craftsman gurus. If the arbor would fix your problem, of course I wouldn't be able to get you one under warranty, but you could purchase one. Go to www.ridgidparts.com. and look under the parts listing for the TS2424
dado, stacked, ts2412
