Re: Jet Proshop vs TS3650
Width of cut to the right of the blade:
TS3650 - 36"
Jet - 30"
The JET is advertised with a 1.75 HP motor, but I would bet that the actual "cutting power" of the motors are about the same. Harbor Freight would probably call it a 2 HP! Most of the saws in this range are setup to pull about the MAX from a standard 115 V 15 A circuit to pass certain UL listing. Compare the actual AMP draw for a better idea, although even that gets mashed around a bit as some try to post the startup current.
Although most people will say that the Bies type fence is a superior design, I haven't had any issues with the dual locking style as far as accuracy. But TS3650 fence certainly does make designing an outfeed table difficult as you have to allow the gap between the saw table and the outfeed table for the back of the fence to slide back and forth. I've got a nice, permanent, outfeed table attached (motor is hanging out the back anyway) and many times I've had problems when ripping thin sheet goods that are warped slightly downward as they catch on the start of outfeed table. The JET pictured seems to have a back rail also, but I can't tell if the fence actually rides on it.
Jim
