Go Back   RIDGID Plumbing Forum, Woodworking Forum, Power Tool Forum > Woodworking > Tips and Techniques
Table saw - Lo-Tech blade alignment
Old 02-03-2008, 03:53 PM
niki niki no ha iniciado sesión
Nominated 7 Times in 2 Posts
Nominated Thread of the Week Award(s): 1
Default Table saw - Lo-Tech blade alignment
Good day
I don't have all those "Hi-tech" instruments to check the blade alignment so I "invented" a "Lo-tech" method.
The straight edge must be not only straight but also consistent in width all along (check with caliper).
Instead of the 8"~9" distance of the blade, I'm using a 30" distance (the table length) to measure the deviation and by that, multiplying the mistake and I can adjust the blade parallel to the miter slot much more accurately.
Regards
niki
alignment, blade, lotech, table
