Last weekend I used my TP13000 Thickness Planer for the second time. The first time it ran for about 20 minutes without problem. Last weekend I was planing 5/4 x 12" poplar to 1" thickness. After operating for about 1/2 hour I shut the machine off while I took a break. When I tried to restart the machine the motor would not come on. I checked all circuits and the reset button and everything was fine. I then removed one of the brushes and found it to be about 3/8" long with a large crescent crater. Having not viewed these brushes prior to operating I am not sure what they originally looked like. I put the brush back in and the machine operated. After a few minutes the motor began to slow down and then speed back up and before I could shut it down, it stopped. I checked both brushes and they both had crescent craters (they appear to be broken as opposed to just warn down in a crescent, and the crescent is 90 degrees to the rotation of the armature) and the machine will no longer operate. I called Ridgid and two sets of brushes are being sent. Free of charge I may add. Anyway, I need this machine to operate this weekend. I suspect the brushes will get here today or tomorrow but I am not really sure that the brushes are the problem. Does anyone else have any other ideas just in case the brushes are not the problem....and if they are, why did it happen with less than 1 hour operating time on the machine? Other than it won't operate, I like the machine but I have always been an optimist. Thanks.
Gene
