I've tried the sanding routine, and the "safe" strippers. I've given up all that, it just ends up false economy to me. The only stripper I'll use is the most evil, toxic stuff I can get my hands on. Get as much ventilation as conceivably possible (outside if you can), because they really are toxic. But the job gets done, and it is over.
I got great advice on picking the best stripper. The active ingredient is Methylene Chloride, which is very heavy. If you pick up two (equal sized, of course) cans of stripper, the heavier one has more active ingredient. Follow can directions religiously, and they really work well.
On a chair job that also requires joint repair, I would strip, repair, and then refinish, unless it is going to be completely disassembled. Then I would disassemble first. Whatever you do, mark each and every piece explicitly as to which joints fit together. Chair parts often look identical, but will not interchange.
