Circle Cutters
Old 10-05-2001, 08:42 AM
Ridgid_rocks Ridgid_rocks no ha iniciado sesión
Occupation: Woodworker
I'm looking for a good circle cutter that will work good for hardwoods. I'm trying to make toy cars and trucks and my circle cutter bogs down my drill press when I use it on anything but pine.Any suggestions?.........Donny
Old 10-05-2001, 10:14 AM
I use a General circle cutter (what we used to call a fly cutter). Like other tools, it needs periodic sharpening, could this be the case with yours?
I use mine on the lowest speed my press has (about 200rpm, I think), and plan some patience. If I push the thing too hard it overheats, and generally does a poor job.
Old 10-05-2001, 04:31 PM
Fly cutter are just a slow cutter. Slow the machine down and take your time.
Old 10-05-2001, 04:44 PM
My circle cutter has 2 cutters, does that matter?.........Donny
Old 10-05-2001, 05:12 PM
I don't know what kind that is. A fly cutter has one cutter, looks like this:
I should also note that the cutter is moved depending on whether you want a good hole, or a good circle. Note that in that picture, it is set up for a good hole.
[ 10-05-2001: Message edited by: Dave Arbuckle ]
Old 10-09-2001, 09:06 AM
My circle cutter looks like the one pictured but it has a cutter blade on both sides. They are removeable. Do you think that since having 2 cutting blades that would slow it down any? I figured it would cut faster...Donny
Old 10-09-2001, 10:27 PM
Like I say, never saw one like yours. But one way or another, they have to remove a large amount of stock, and that takes time. If you had a hole cutter with a kerf wide as a fly cutter, it would be really slow cutting too.
Old 10-10-2001, 12:50 PM
Hergy Hergy no ha iniciado sesión
Occupation: Retired-Lucent Technologies
Don, might try taking a look at Rockler.com. They have a fair amount of toy parts including wheels. Seems to me like I have seen a tool for making wheels. They also have a number of premade wheels and I suspect that some of them may have involved the use of a lathe. Unless you are dead set on making your own wheels, perhaps buying them would be an option.
Dick
Old 10-12-2001, 11:36 AM
Don, I gave you the wrong supplier. Sorry about that. Woodcraft carries a rosette and wheel cutter. This may be what you are looking for:
http://shop.woodcraft.com/woodcraft/...=false&Giftid=
Wow! that's a URL and then some.
Dick
Old 10-12-2001, 12:16 PM
Thanks, I'll check it out......Donny
circle, cutters
