draining condensate trap
Old 01-16-2005, 10:19 AM
melonworm melonworm no ha iniciado sesión
Occupation: production mananger
If I am not allowed to ask DIY questions, forgive me.
Our Lennox Pulse 21 is running intermittently. Upon reading and researching we are 99% sure our condensate trap is the culprit. I am not too keen on cutting off the bottom of the PVC monstrosity that is our condensate trap. Nor am I too keen on hubbys idea to shop vac it (sounds reasonable but I am scared of the unknown) Is this a job ok to do on your own or is it best left to the professionals? Hubby is very mechanically inclined.
Old 01-17-2005, 03:08 PM
jeff jeff no ha iniciado sesión
Occupation: service tech.
just below were it comes out of the furnace you should see what looks loke a coulper if you look close you will see that its a male female joint it is above the dain outlet take the drain off and unscrew the two pcs. becarful with the wrenche not to break the pvc then flush out the trap and put back together use telon tape to make it easer to come latter good luck
Old 01-22-2005, 06:07 PM
photoman250 photoman250 no ha iniciado sesión
Occupation: HVAC
You can "suck" out any trash in the drain. of course you have to do this from outside where tha drain exits the house, using a wet/dry vac works well as long as the drain isnt too clogged up.
condensate, draining, trap
