Welcome to the RIDGID Forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and limited access to our other board features. By joining our FREE community you will have access to post topics, reply to messages, communicate privately with other members (PM), respond to polls, upload content, view attachments, access to the Image Galleries, RIDGID Chat Access ,and access to many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact contact us.
Installing gas furnace for shop
Old 11-07-2002, 10:53 PM
Woodchuck Woodchuck no ha iniciado sesión
Occupation: VW Auto Technician
Doing a little pre install research on what's required to install a gas furnace in my new 42x30garage/shop. Our township does ahear to standard building codes and maybe someone could offer some suggestions. Since the garage/shop will have auto's parked inside I guess I need a overhead mounted heating unit with about an 80,000btu rating. The line from my house to the garage is about 60 feet. What size of gas line do I need? Electric is burried in plastic conduit about 18" down. How deep should the gas line be and can it be in the same trench?
Old 12-18-2002, 01:41 PM
The Pipe Dope The Pipe Dope no ha iniciado sesión
Occupation: Plumbing/Mechanical Inspector
In order to size the gasline, you need to know the available pressure, and the type of gas being used(LP/Natural). Gaslines need to have 12" of earth cover, can be laid in the same trench as electric, but must maintain 18" of separation between the two.
Old 01-01-2003, 09:50 AM
Kenneth Kenneth no ha iniciado sesión
The best thing you can do is pull a permit and ask your local code inspector what he will allow in your area.I know what is code in mi. but your neck of the woods is probably different.Under no circumstance do you want a fur with the burner less than 18 in from the floor due to gasoline fumes.I too want to put heat in my pole barn and I am considering ceiling mounted tube heating such as you may see in some commercial bldgs.We have that in our service facility and it works very well.
Old 01-01-2003, 11:04 AM
Since posting and getting several estimates from HVAC installers I have several options. Ceiling units, outside intake for combustion, or mounting a min of 18" above floor. Since I will be replacing the furnace in my house this year( from 60% to 80% efficent upgrade) will move the old unit into the shop/garage!
Old 09-08-2003, 09:34 AM
Van Van no ha iniciado sesión
I am also considering using natural gas in my shop (planning stages only).
Could anyone please be brand specific.
My shop is only 12'x20' and is 100' from my home.
I've considered a wood stove but as a hobbist I know there will be wintry weeks of infrequent use, but still want to maintain minimum temperature for freezibles.
Maybe a stove + electric?
As you can see I am all over the lot on this one.
Old 09-08-2003, 10:08 AM
Woodchuck, don't want to steal your thread. Just looking for brand names to research. Sorry [img]smile.gif[/img]
Old 11-20-2003, 12:31 PM
FlyntG FlyntG no ha iniciado sesión
Occupation: HVAC
i'd simply use the woodburning stove in conjunction with a small space heater. just leave the electric heat on a very low setting, just enough to keep the shop from freezing.
furnace, gas, installing, shop
