HVAC Duct Replacement
Old 09-01-2005, 11:41 PM
RoseRx RoseRx no ha iniciado sesión
I was up in the attic recently of my 25 y/o home & I noticed that some of the duct work is deteriorating. How big of a job is it to replace & are there newer & better products out there?
Thanks!
Old 09-02-2005, 08:51 PM
Would we be correct in assuming it was galvanized sheet metal duct work?
Old 09-03-2005, 12:37 PM
No, it's not galvanized metal, but the fiberboard w/ the silver exterior.
Old 09-03-2005, 01:37 PM
ToUtahNow's Avatar
ToUtahNow ToUtahNow no ha iniciado sesión
Years Experience: 37
Nominated 96 Times in 24 Posts
Nominated Thread of the Week Award(s): 11
RoseRX,
The work is fairly simple if you don’t mind working in the attic and you stay on the joist. The new ducts you should use have the insulation wrapped around spring type flexible ductwork which is incased in a plastic sleeve. Assuming the wyes and boxes are sheet metal you can reuse them and just replace the ducts size for size. Be careful to properly support the new ductwork so it is not kinked.
Another issue to watch for is your old ductwork may contain Asbestos. If it does you will need to find an abatement company to remove the old ducts which may make duct replacement impractical cost wise.
Feed Phoebe Jacqueline!
Old 09-03-2005, 07:22 PM
imported_Bob D.
Mark, I have never heard of asbestos being used in fiberboard duct.
I think the fiberboard is a pain in the butt from a homeowners point of view. It sure is easy enough to install though. I remember replacing a few pieces when we installed new AC units and had to make up a new transition pieces. A couple simple tools and special cutters for making rabbits and miters, a razor knife, and a few rolls to metalized tape and you are in business
But for myself I would not want it in my house. The air breaks off small pieces of fiber that then float out the duct and into the air you breathe and it settles out on everything making a dusty mess. Can't be too good for your lungs either.
Old 09-03-2005, 09:29 PM
ToUtahNow's Avatar
Bob,
We used two types of fiberboard ducts. The first was corregated like cardboard and the second was just board. At different times each contained Asbestos but in small amounts. Then to complicated matters we used an Aabeatos tape with wheat paste to seal the ducts. I don't believe either could hurt you in smaal amounts. I have choked from Asbestos dust more than once and I am still here. Still the fine for improper disposal of Asbestos is more than the cost of abatement.
duct, hvac, replacement
