cleaning router bits
Old 09-01-2004, 12:48 AM
bourne502 bourne502 no ha iniciado sesión
Purchased my first router recently and noticed that after some work with pine, the router bits had a build up or gummy coating on them. Any suggestions on how best to clean them?
[ 09-01-2004, 01:06 AM: Message edited by: bourne502 ]
Old 09-01-2004, 05:37 AM
K.M. Delano's Avatar
K.M. Delano K.M. Delano no ha iniciado sesión
Simple Green and a tooth brush.
Support Our Troops!
www.mnpatriotguard.org
www.patriotguard.org
Old 09-01-2004, 08:45 AM
imported_wbrooks
I use CMT 2050. it is non toxic as well. spary on, let sit for a few minutes then wipe off the pitch. For stubborn spots either let it soak longer or use the toothbrush
Old 09-01-2004, 03:13 PM
imported_Knot Me
I've successfully used Simple Green, Goo Gone or Goof Off citrus cleaners, Dawn, and Boeshields Blades n Bit cleaner. All seem to do a good job with a stiff brush.
Old 09-04-2004, 08:42 AM
Andrew M. Andrew M. no ha iniciado sesión
Occupation: remodeling
Be sure and remove the bearing if the bit has one so that you do not damage it with the cleaning solution. I use synthetic oil inside the bearings to increase the lifespan.
Solvent or a neutral ph cleaner is best as not to attack the braze on the carbide.
Old 09-07-2004, 10:02 AM
Mike3206 Mike3206 no ha iniciado sesión
Occupation: Facility Coordinator
There is a very good test in a recent issue of Wood magazine IIRC. (the new one out) they tested a bunch of different cleaners. The ones that did the best were made for cleaning blades and bits. I also believe that there is a how to arcticle on router bits in one of the new mags as well. It could be Wood, but I can't remember.
bits, cleaning, router
