Welcome to the RIDGID Forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and limited access to our other board features. By joining our FREE community you will have access to post topics, reply to messages, communicate privately with other members (PM), respond to polls, upload content, view attachments, access to the Image Galleries, RIDGID Chat Access ,and access to many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact contact us.
DP1550 Pulley alignment problem
Old 10-28-2003, 04:57 PM
Tool Tool no ha iniciado sesión
Exclamation
I pulled the trigger on a Ridgid DP. It seems I am the latest to be hit by the problem Ridgid is having with the pulleys on the DP1550. I did a search of the archieves a got tons of hits, but not any with solutions.
Many of the issue I read people had were due to the idler pulley being low. Well I have the opposite problem. On mine the idler pulley is too high. It is about 1/8 higher than the spindle pulley and about 3/16 higher than the motor pulley. Though I have not tried yet, I can try to raise the moter pulley in line with the Idler puller (th manual covers this adjustment), but then I will still need to raise the spindle pulley. I don't see any way to move the spindle pulley up though and no mention in the manual for adjusting the spindle pulley.
The sad part is that the manual states: "Pulley alignment is set at the factory and should not require furthur adjustment"
Hope this is clear.
What should I do? I plan on calling Ridgid, but what should I ask them to do replace the whole head assembly?
Thanks for your help in advance.
Anthony
alignment, dp1550, pulley
