tacman, you're in southern calif. why not let the gas co come out and look at it. they can measure the pressure,
a word of advise, if the problem is a danger, they will shut off the unit.
this can be a good thing or a bad thing.
i have a new customer that called me 2 days ago. he was having problems with his furnace. the gas co came out and determined that the main from the gas meter to his house is restricted, ( not leaking). they shut his gas off wednesday.
personally, if the line is not leaking and this has been an ongoing problems for months. why shut off the gas to the whole house
no hot water or heat.
i'm going there today to check it.
a real dumb question. where in southern calif do you live that you use propane? and this is southern calif. i've had to run the a/c to cool things off these last few weeks
