Welcome to the RIDGID Forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and limited access to our other board features. By joining our FREE community you will have access to post topics, reply to messages, communicate privately with other members (PM), respond to polls, upload content, view attachments, access to the Image Galleries, RIDGID Chat Access ,and access to many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact contact us.
Humidifier
Old 03-06-2006, 12:55 PM
Pipestone Kid's Avatar
Pipestone Kid Pipestone Kid no ha iniciado sesión
Nominated 19 Times in 4 Posts
Nominated Thread of the Week Award(s): 2
Question Humidifier
I have an Aprilaire humidifier on my furnace. Last summer I installed a 100,000 btu furnace (Heil) to replace a 70,00 btu (Goodman) that wouldn't keep up in really cold weather. The humidifier worked fine in the past (windows would really frost up if I forgot to turn down the humidistat in really cold weather) but since the new furnace is in, it doesn't do the job. I've put in a new media, checked that the air flow is coming through the duct from the humidifier, and watched to be sure the water is flowing through the media as it should. Everything seems to be o.k. Two questions--1. Would the speed of the fan have anything to do with this? (The fan is at the medium setting) and 2. Would the increase in BTU's have an effect? Any ideas would be appreciated.
Jim
Old 03-09-2006, 07:55 AM
wbrooks's Avatar
wbrooks wbrooks no ha iniciado sesión
Occupation: IPSC E. Eng
I had a similar problem with my flow through style humidifier. What I did was hooked up an in-line booster fan (from HD) wired off the furnace control board to come on with the main blower during the heat cycle.
Click image for larger version
ID:	142   Click image for larger version
Wayne From Pontypool
Old 03-09-2006, 09:26 AM
Wayne: Did that solve the Problem? I seem to have a lot of air flowing through, but maybe it isn't enough. Sounds like it might be worth a try. Thanks for the response.
Jim
Old 03-09-2006, 02:35 PM
wbrooks's Avatar
It helps a lot, I can get the humidity to stay over 30% when it is really cold, where as before the upgrade I was in the low 20's with really bad static. Now I rarely get a static shock. It was a cheep fix and seem to work well enough. The real solution I think is an outside air exchanger
Old 03-09-2006, 06:34 PM
dietz dietz no ha iniciado sesión
Jim,
I sell this equip for a living (wholesaler). Some of the isssues are: Is the model you have a bypass style (sounds like it may be this type) or is it mounted directly to the plenum ? What is the square footage of your home ? (some of the bypass units will only handle so many sq. ft.) Also one thing you can also do to help is attach the feed line onto your hot water side about six inches up off the tank (hot water will atomize quicker than cold !) I agree in saying your best bet would be a fresh air exchanger but this may not be feasible.
Your fan speed setting is fine (medium for heating). This may sound stupid but make sure if there is a damper its in the correct position, and the the humidistat is set to approx 35%.
Ted
Old 03-10-2006, 09:19 AM
Thanks a lot for the reply, guys. TED: The humidifier is attached directly to the plenum. (I will try to post a pic later, if I can make it work) Square footage is about 2200--Story and a half house total sq. ft. Water is attached to the hot side-about two feet from the tank. Before I changed furnaces, I could make water run off the windows easily if I set the humidistat high enough. No such luck now--even at 20 below zero. The unit is on the same plenum--didn't have to change that. ????????
Old 03-10-2006, 02:05 PM
Ted: I tried to post a pic, but it was too big for the forum--I don't know how to reduce it to be able to post it.
Jim
Old 03-11-2006, 04:30 PM
senator91 senator91 no ha iniciado sesión
I wonder if it's wired differently. I mean what has really changed? 30,000 BTU's shouldn't prevent it from being effective. Maybe it was connected to run longer previously. i.e. wired to fan instead of ventor motor. If your furnace has taps for humid. and EAC, try wiring it to the EAC taps. That may give it a longer run time and help a bit. The only other thing I can think of is if the orifice is partially blocked and water flow is less than before.
Old 03-11-2006, 05:58 PM
I agree nothing in the setup changed except for the increase in BTU's (except for any variance in the way it was / is hooked up. Are you hearing the solenoid open and flow water at the same moment that the t-stat calls for heat ? If it is mounted directly to the plenum, then it is what we call a power style. This has fan assist (is it running ??). Do you remember at what point in the heating cycle it turned on with the old furnace compaired to how it comes on now ??
Old 03-11-2006, 06:43 PM
Dietz and Senator91: It is wired the same as it was before--solenoid opens and closes with the furnace fan.(No fan assist on this model) Lots of water flowing through the media. I will check for EAC taps and give that a try if they are there. Just to give a recap--I thoroughly cleaned the unit, put in a new media, wired the same as before, goes on and off with the blower(circulates the air past the heating panels, not the power vent) I will let you know about the EAC. Thanks,
Jim
humidifier
