Contractor computer case
  • Contractor computer case
    http://www.pelican.com/cases_detail.php?Case=1490CC1
    This is the case I went with for my laptop. Pelican of course is known for it's excellent quality but this is well designed. I have plenty of room for all my stuff and I don't worry about the laptop getting bumped. I was able to stand on the case with no damage and I weigh 265. The one drawback is this case is heavy so it might not be the best one when long walks are involved.
    Re: Contractor computer case
    How does the laptop breath?
    Also will the case keep the laptop cool, when left in the truck/van during daylight Sunshine 160* plus, because the windows are rolled up?????
    It does look very durable, no doubt there.....
      What are the dimensions of your laptop?
        I take it out of case when in use. It's waterproof so you can put it in the cooler to keep it cooler. lol, I don't know about the heat issue.
          14 1/8w x 10 1/4 front to back x 1 3/16 thick. The case can hold a laptop 14 3/8w x 11".
            Be careful to make sure it is really off. When I close my laptop it doesn't really turn off entirely, so it can build up a reasonable amount of heat in my laptop bag on the drive from/to work if I do some errands along the way.
              Get a Toughbook and be done with it.
                Nice thought but most don't have that kind of income to put into one. Unless you know somewhere you can get one for a reasonable amount. I'm all ears.
                  I second this advice. i once put my laptop into hibernate and put it back into my laptop case. It literly melted the paint off the back of the battery overnight.
                  Josh
                    Finally got a new camera and here is what it looks like. The white thing is a cooling pad.
