Mini Laptop Recommendations
    Re: Mini Laptop Recommendations
    Originally posted by VASandy View Post
    Netbook CPU's are typically those found in small devices like Palm PDA's and some phones. They're not tremendously fast. If you don't need a lot of horsepower for the apps you do, then a Netbook for the road is a good idea.
    Not true about being the same processors in PDA and some phones. The processors in the netbooks are Intel Atom Processors. They are the newest processors for UMD, MID, netbooks, nettop applications thatare low powered using 1-2.5W and performance scaling range from 800MHz-1.86GHz and are also known as codename Silverthorne. The processors used in many of the cellphones and PDAs are usually ARM processors. If you want to know more about each one, I would suggest researching the processors that are in the device you are considering to purchase. Also make sure if you are going to get a netbook, get a 6-cell battery version instead of the 3-cell for longer play time.
      very true as our acer aspire 1 has the 6 cell and we get a good 5-6 hours each. that's at full time screen brightness.
