EB4424 oscillation problem
  • EB4424 oscillation problem
    My EB4424 spindle sander has stopped oscillating and the spindle remains fully extended upward and it sounds like a gear is slipping. I opened up the gear housing and found that the retainer clip on the end of the motor shaft had popped off. I replaced it, reassembled the unit and turned it on. It made one cycle then the same failure occurred but, when I opened the housing again, the circlip was still in place. This is a very easy assembly to access and repair however, I would like some guidance on what part(s) I need to order. I have found a very clear parts digram but am not sure what to replace. I can't see any visual damage. Any help here would be much appreciated.
    Re: EB4424 oscillation problem
    I'm strictly guessing here, but I assume there's a belt, and if so, how's the tension/condition of it?
      Good guess but, there is no belt. There's some funky looking gears on the single motor shaft on the opposite end from the drive end. Also, a plastic housing over that assembly that also has internal teeth.
        If you have the receipt take it in and get it fixed under the lifetime service agreement
