Temperature Adjusting Chargers
  • Temperature Adjusting Chargers
    Temperature correcting battery chargers. If the battery is above or below the normal temperature for good charging the charger will either supply some heat or will blow air over and maybe even through the battery for cooling. Maybe the battery packs and the charger can have special contacts for temp sensor and an internal heating element.
