Aresol snake cable rust inhibitor.
  • Aresol snake cable rust inhibitor.
    This idea was spawned after using the Ridgid aerosol threading oil. I love it! I think it would be great to have the Ridgid cable rust inhibitor in an aerosol can as well. Would make it much easier to apply. I would definitely buy it over the gallon or quart jugs I am buying now even if it was a little more $$$.
    Ray
    www.mauiplumbinginc.com
    Re: Aresol snake cable rust inhibitor.
    I buy wd40 by the gallon and use a spray bottle bought from HD.
      Problem with wd-40 is what ever you spray it on tends to collect dust very rapidly. I am using Breakfree CLP now it's expensive but works great.
      Ray
        Never had a problem with my cables collecting dust. Just take your cage to the street and spray away. Done in less then a minute.
          i started to use an aerosol motorcycle chain lube. seems to hold up well to water and is thicker weight than wd40. the only thing i'm lubing are the couplers and pins at the ends of each sectional cable.
            I need a rust inhibitor though, if I don't spray something on my cables @ the end of the day after use the next day the cables have surface rust !
            Ray
