I would love to see a 10" SCMS
  • I would love to see a 10" SCMS
    I really don't need a 12". A 10" would be great because I can use the blades from my 3612. I like the 10" but I really need the sliding function too.
    Any Plans?
    thanks
    eric
    Good post. The price of a 12" blade well out weighs the added demensional cutting capacity. And if your like me, the RAS and MS share blades as they are of the same type of top cutting machine requiring a 0 or negitive rack blade. I often use the miter saw for rough cuts for shortening longer boards, and doing the more precision cuts with the RAS. The RAS, seams to give a much better finish cut using the same blade than the MS due to blade angle/rotation exit angle.
    A slider, will actually have the same as the RAS, as you pull, start, lower, push the blade into the stock. With an upward blade spin direction on exit, you will by far experience a cleaner exit cut and smoother cut all around.
      It's time for rdigid to step into the 10"scms market.
      Andy B.
        Yes we need a 10"scms! the 12" is great but not to portable.
          when I upgrade to a CMS, here is the one I will buy
          http://www.milwaukeeconnect.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=27&catalogId=40027&langId=-1&productId=284465&mainHeader=Tools&categoryId=189 345&mainCategoryId=362 &parentProd=281175
