Trash can wet/dry Vac
  • Trash can wet/dry Vac
    How about a wet/dry vac that would fit on a 32 galon trash can? It could have a flat base which would cover the top of various size trash cans and be secured to the can by clamping it to the handles or the rim. The bottom side of the base could be covered with some high density foam to make the seal to the top of the can.
    The advantage of this configuration is you could fill up a can with debris and then move the vac to another. you then just place the trash can's lid on it and haul it away. This would be great for use on bulky materials like sawdust, wood shavings from power tools like planers and joiners, etc. Also work with leaves for yard work and for picking up water.
    [ 02-22-2004, 07:15 AM: Message edited by: Bob D. ]
    i was thinking about this very thing. milwaukee has a 55g drum shop vac attachment for their vac's. was wondering if ridgid offered the same?
