nerw impact driver
  • nerw impact driver
    why not making something to replace this
    14.4 Volt Impact Driver Kit
    R82320Cat #20588
    Features
    High torque motor and gear box design – the power to complete the taskVariable speed switch – for easy starts and stopsDie cast gear box – for more rugged, reliable and dependable operation1/4 in. quick coupler – for quick and easy bit changesCompact size – fits into tight spaces
    Specifications
    Impacts per Minute:0-2,800Max Torque:1400 in.lb.Collet Size:1/4 - in. hexNo Load Speed:0-2850 r/minCharge Time:Max Batteries:30 min.Standard Batteries:20 min.
    Includes
    RapidMax 30/20 minute charger, 1 standard battery pack, 1 single ended impact bit, and case
    WITH THIS
    • Ultra Compact at 5-3/4" in length and 2.8lbs with battery
    • Makita built,4-pole maximum torque motor delivers 1,280 in.lbs.of efficient torque in a compact size
    • Batteries charge 4X faster in only 15 minutes
    • Ergonomic shape fits like a glove with even pressure and easy control
    • Built-in LED light illuminates the work area
    I would use you as my christmas present and not makita
    Re: nerw impact driver
    Isn't that the newer MaxSelect impact driver that replaced the old styles? Is that what you're looking for?
