How To Post Images
See more
See less
Ridgid Kollmann SeeSnake b/w monitor price?
    Re: Ridgid Kollmann SeeSnake b/w monitor price?
    My problems is probably the Horizontal Stripes on monitors and It says that normal because the transmitters is activated but even when the transmitters button is not activated it does. that you already do that?
      the older sondes were alway active.
      send a photo of the sonde and i can verify. if it has 2 antennas sticking out from the end, it's the older units.
        what is the sonde ? I probably know what is it but in french...
          Transmitter built into the head of the pushrod near the camera lens.
            i made a video, the black stripes is normal its my camera, the problems is the white small stripes. (it appears at 0:29) i think its the older sonde. Seensnake Ridgid Kollmann b/w color - YouTube
              my guess is a short in the wiring between the pushrod and the camera. pretty common with lots of use and flexing of the sonde.
              i would have a service center isolate the problem and determine if it needs a new sonde, camera, slip ring, termination.
              i vote sonde is damaged.
                ok were can i find this service center? Tanks
                • #23
                  its ok, i found a service center nearby. What is the price of a new sonde?
                  • #24
                    last time i had to buy 1 it was $600 usd.
                    have the service center check things out. it might just be a loose connection.
                    also check the 2 stainless safety cables that run next to the sonde inside the spring head. make sure they haven't rubbed through the wire insulation.
                    • #25
                      ok thanks
                      • #26
                        Hi!
                        I went to a service center and the monitor is number 1, but he did not notice the bug on the camera and I spoke even here it does more. This is the only service center for SeeSnake in Quebec. It bothers me
                        • #27
                          I am a little confused here. I do see the horizontal lines in your video but I believe they are scanlines and the way your camcorder is picking them up. I noticed that they start out horizontal in your youtube video but then you turn your camcorder and the line orientation follows the way you are holding the camcorder.
                          So I wanted to confirm.... does this show up when you are just looking at the monitor or only when you are video taping the screen? If its when you are taping the screen, there isnt really anything you can do about it. its the way older monitors show up when video taped.
                          I do not believe the lines have anything to do with your transmitter.
                          • #28
                            If I remember correctly, it was when I was recording it, but she stopped doing the problem. Finally, it may be normal as you say, it's old stock
