Step Bits - Which One is Best
  • Step Bits - Which One is Best
    Came across this YT video tesing about a dozen different step bits.
    As we all know some are junk and it's not always price that defines quality.
    https://www.youtube.com/watch?v=nGbMQul6_Bc
    I have used the Harbor Freight step drill for many years.
    I have the small size with the hex bit end that goes to 1/2"
    I also have their larger sized step bits that you have to use
    a regular 3/8" drill chuck to secure them.
    As a DIY'er I still have my "original" step bits ...I do not abuse them.
    Then, I do not use them daily.
    I usually drill a pilot hole 1/8" or 3/16" with a regular drill bit and then use the step
    drill to increase the hole to the desired size. More times than not I use regular drill bits to get
    close to the size hole and then the step drill to quickly adjust the hole size.
    When I use them in metal..steel or aluminum...I always use cutting oil and drill slowly.
    Speed of drilling a hole has never been an issue for me.
    Cactus Man
