The FEIN has minimal vibration, noise and the Starlock Plus tool mount is awesome. Hope you can find some in your area as it’s not a normally stocked item. Great that Diablo makes more affordable blades that fit the FEIN.
HD clearance on FEIN
Always wanted a FEIN Multimaster but “settled” with the much less expensive version from HF which were awful: heavy vibrations, loud, blade gets loose, gets real hot to hold, overheats and stops working in the middle of the job.
The FEIN has minimal vibration, noise and the Starlock Plus tool mount is awesome. Hope you can find some in your area as it’s not a normally stocked item. Great that Diablo makes more affordable blades that fit the FEIN.Last edited by reConx; 05-21-2022, 10:06 AM.Tags: None
Nice. I bought a Fein years ago when they were the only game in town except for Festool but Fein was makes Festool's oscillating tool and still does as far as I know. Many accessories are interchangeable so keep that in mind.
Mine is a MM250Q IIRC. Paid almost $300 for it and that was about 15 years ago. I got the JobMax with the 12 Volt and the AC (120v corded) consoles when that first came out and used them almost exclusively until I got the Festool OS400 kit. I still have all three but the RIDGID JobMax is still my favorite of them all. Probably because it is the only cordless one of the bunch. I find that little 12V sucker has got enough power to do almost anything. I am really sad they discontinued the JobMax line."It's a table saw, do you know where your fingers are?" ? Bob D. 2006
http://cordlessworkshop.net/
- Likes 1
I had an older Fein up until a few years ago until I burned out the drive system. I tried several different manufacturers until I settled on the Rockwell. I certainly like the Fein but with the new blade lock system the blades a horribly expensive.
