my "lug nuts" are leaking
  • my "lug nuts" are leaking
    had a job yesterday that the customer called and told me the lug nuts on his water heater are leaking
    this is a 2 year old home and i figured i would look at it to see if the wheels were falling off
    turns out his lug nuts are actually the bolts that hold the flange together for his circulating pump.
    his pump is not plugged in as the line circulates by itself due to temperature differential since his heater is ground floor in the garage and the house is 2 stories.
    cut out the pump assembly and propressed the pipes back together after draining and flushing the 75 gallon heater.
    and i thought i was going to see my first heater on wheels
    notice the seismic strap for those not in earthquake land.
    Re: my "lug nuts" are leaking
    Is there a check valve on the return line?
      never was and it still auto circulates
      the house is right around the corner from your auto parts store
