Pipe bursting prep setup.
  • Pipe bursting prep setup.
    prepped for a pipe bursting job that required me to core drill a 7'' hole under the house to allow the bursting head to pass through the foundation. used my smaller coring setup as dragging my monster setup under the house was not going to be fun. all went well except when i hit a piece of rebar on the edge of the hole. so instead of cross cutting the 1/2'' bar top and bottom, i ended up having to rip the bar approx 3''. my smaller machine in low gear is rated for 6'' and i was pushing it at 7'' plus the rebar.
    today is the bursting job that consist of a 35' pull from under the house, through the wall, then under a tiled patio where it 45's and continues to the sidewalk at 45'' deep. ground is full of roots and hard rocky fill. pipe was all broken on the bottom and was only getting worse. i have maintained this line since 2004 once per year, but now it's history as it's beyond routine cleaning.
    Rick.
    cutting the line close to the wall to allow the 7'' core bit to clear the pipe.
    1/2'' anchor bolt to attach my coring stand.
    7'' hole with minimal water.
    ripping the 1/2'' rebar at the left side of core.
    front of house next to sidewalk with the hole dug and protected overnight. approx 4' long. 2.5' wide and 4' deep.
    Now come on we want a full commentary movie not still photos of the whole project surly the misses can hold the camera
    Tony
      I never got into coring, always bring in the pros, but I know several plumbing contractors that do their own. Have fun with the pull.
      David
        here are a few photos of the bursting job.
        40' all prepped and fused being pulled through the new 7' cored hole.
        bursting head that pulled into the pit.
        pulling pit with square front wall. this is very critical to get the machine to stay put and not creep sideways. shoring is also important to keep from pulling into the dirt wall.
        a look into the pipe prior to the pull. this was the good stuff. under the patio was all broken up on the bottom.
          Did you camera the patio section after the pull? I ask because if there is no bottom in the pipe they will sometimes belly there because there is no resistance on the bottom then the pipe bumps up when it gets to good pipe.
          Seattle Drain Service
            it looked fine as there was a 45 turn in the first 4' so the pipe took a new course with the new long sweep 45. amazing how it really shortened up the original camera distance with the new path.
            Rick.
              here is a sample i showed the homeowner when he got back home. it's a butt fused piece that is 3'' long that's been run over by a truck tire and flattened, then rerun to flatten it the other way, then flattened again. this shows the weld is not going to break.
              Rick.
              4'' hdpe pipe being flattened at the butt fusion joint.
              pipe and weld still in tact. didn't break or split.
                Did you use the data logger? j/j
                I haven't heard of hdpe being to common in Michigan for sewer replacement. I have done a ton of it but that was at a refinery for fire main.
                16"
                  Rick.
                  Thanks for posting the details and pics of the job, Its not something I see very often here in San Diego.
                  I have never used the pipe bursting method but it would have come in handy on more than one occasion!
                  Mind if I ask what type of pipe bursting equipment you use and do you ever take the lateral all the way to the city trunk line in the street?
                    Mine was an original chain unit made by pipe geni. Bought it 15 years ago.
                    Its possible to pull to the city main with 6" hdpe, but you need a c42 license. I never did that nor 6" too. But it has the power to pull 6" with 40 tons of pull.
                    Rick.
                    Welcome to the forum.
                      Thanks for the reply and the welcome Rick.
