contamination
  • contamination
    Whats the deal. If your threading black pipe with a set of lets say 1'' pipe dies and then use the same dies on stainless steel pipe, will the stainless get contaminated with the carbon from the black and start to rust.
    Re: contamination
    Not a chance................. The stainless doesn't lose its chemical composition by being worked on.
    just wipe any SURFACE contamination off.
    Syn
      Re: contamination
      you shouldn't be using the same dies for stainless and for steel.
      the oil should wash away the "fines" that are cut.
      is the stainless just rusting at the cut threads? how is the rest of the pipe and how about the factory threads?
      or is this just a hypothetical question?
        Re: contamination
        Syn
        Guess it depends on where you are and the standards that must be met. We are not allowed to cut CS and SS on the same machines. We can't even use regular old duct tape or magic markers or Sharpie® pens on SS; have to use stuff verified as chloride free so it won't affect the SS.
          Re: contamination
          thanks for the input, and no its not hypothetical, why should you not mix cs and ss. is this writen as a cold hard fact. been hearing this nonesence for a while. i personally have never heard of this. thanks for your time guys
