Picture Not true to fact
  • Picture Not true to fact
    I just purchased a WD14500 Wet/Dry Vac. In assembling, the instructions show that you can put the male end of the wand on the rear leg with the hose still attached to the wand. I haven't found this to be true yet. The hose only fits on the male end of the wand so you can't keep them together when trying to put them in the holder. Am I doing this incorrectly, or is the picture in the instructions just wrong?
    Re: Picture Not true to fact
    I believe "it's just wrong".
    As I recall, this subject was posted at least once before and was confirmed that the photo was in error.
      CWS is correct. The picture is wrong in the manual. Only the larger female end fits.
      Your hose should be so the end on the hose fits into the female end of a wand. For storage the wands (female end) fit on the caster brackets, but the hose must be removed first.
