Trying to help another poster
  • Trying to help another poster
    I received a message from paulbes on 6/2 and thought I would copy it to here. Not sure what to do maybe someone else has a suggestion.
    "Fairly new to this site, but a lot of great information. Seem to be having a problem seeing new posts. I tried posting a new thread but it didn't work and I only see one new post in the woodworker expert section over the past day or so. Are there issues with the site? Is there a fix I can try. Thank you,
    Paul"
    If there's something I can forward to him, it would be appreciated.
    If at first you don't succeed, try reading the owners manual.
    Re: Trying to help another poster
    Maybe this thread would help
    Cheers! - Jim
      While logged in to the Forum, go to the User Control Panel.
      Click on "Edit Options" in the left frame about half way down in the Settings & Options section.
      In the right side frame check your "Default Thread Age Cut Off" setting. I believe the default is to show threads for the past month, but there is a selaction to show only those threads from the past day, in which case you would not see any posts older than yesterday.
        Thanks I'll see what works.
