New Look - Much easier to read
  • New Look - Much easier to read
    Everyone, I just update the templates for RIDGID chat. If you havent been into the ridgidchat before you will see the new changes.
    If you have been in before heres all you need to do. Next time you are in RIDGIDchat simple click on the options button then under the themes dropdown choose ridgid. You should have the new RIDGID theme that is much easier to read text on.
    Josh
    Re: New Look - Much easier to read
    Josh
    Hi Josh,
    I checked ours and i is still the same..is it cause we messed with color of the background and transparency an dit will be here till we change it
      Zeljka, see the second half of my post
        I did and it is all white after i select ridgid
        i'll let robert mess with it when he comes home
        thanks
