What is it?
  • #46
    Re: What is it?
    Originally posted by plumberscrack View Post
    Part of it looks like my 65R ratchet but the sliders and pegs has me fooled.
    Is it homemade?
    Nope it is as I recieved it brand new. I will add a close-up later today which may make it easier to identify.
    • #47
      Re: What is it?
      To continue on the trend of tools I'll add one from my field of work.
      Hint: I use one as a field biologist but I am not the only natural science field to use it.
      • #48
        Re: What is it?
        An over engineered plumb bob?
        Looks like something to get a water sample from the bottom of the ocean
        • #49
          Re: What is it?
          Gah!! Got it on the first guess. I'll have to find more obscure equipment that I use. It's called a Kemmerer Sampler and it's used to get water samples below the surface. Its really basic but works like a charm. You drop the tube with both ends open so water can flow through until you reach whatever depth you want to take the sample at. Then you drop a weight down the line and when it hits the sample it makes both ends seal up and just like that you have an uncontaminated sample of whatever depth you want.
          • #50
            Re: What is it?
            I would have never got it without the clue.
            I think I saw Jacques Cousteau use one once. I always wanted to be like him
            • #51
              Re: What is it?
              Mike Nelson (Lloyd Bridges) was the first person I saw use one.
              Just kiddin.
              I did guess correctly (I figured it was for taking some type of sample in a liquid) but PCrack beat me to it. I've seen the plant chemists use something similar to collect samples from various vessels around the plant.
              • #52
                Re: What is it?
                Haven't forgotten about that tool Mark, what is it?
                • #53
                  Re: What is it?
                  Okay here is a closer picture of the tool. It is a ratcheting Companion Flange wrench. The posts are changeable depending on whether you are using a standard flange or a HD flange. Then it is made to slide in or out so it can handle anything from a 2" flange through a 6" flange. On the backside of the wrench is a level which tells you when the flange is square.
                  • #54
                    Re: What is it?
                    a ratcheting adjustable pin wrench, (and looks like Ridgid made it), but what it is used for specify, I don't know, (large valves is my guess)
                    • #55
                      Re: What is it?
                      It's for installing Companion Flanges but it was not made by Ridgid. I have never been able to identify who made it.
                      • #56
                        Re: What is it?
                        Originally posted by Woussko View Post
                        This is for all the nice young ladies on this forum.
                        Aww...
                        Woussko the gentleman....You give me more roses then my hubby does..this will teach him a lesson
                        • #57
                          Re: What is it?
                          Zeljka
                          Woussko best not be giving you more flowers than your Mister. You're married to a good guy, Robert and that means Woussko has to be a good old hound dog and not bother you. I'm glad you do like them though.
                          They are for everyone on this forum.
                          • #58
                            Re: What is it?
                            I know this ios some sort of marking tool, but I don't know what for. Any ideas?
                            • #59
                              Re: What is it?
                              well nobody replied in over two years so I guess you won the game.
                              what is it
