Canadian rental options
  • Canadian rental options
    Hello
    I'm working on a project that has 12" steel pipe (Farm tank foam system - fire protection). I don't deal with anything greater than 6" and this is reflected in the tools we have. I don't foresee too many of these large scale projects in the future either so I's just like to rent the equipment (258xl power cutter / AR99 stands / 918 groover / etc..) Any Canadians here with thoughts on the matter?
    Thx
    Dave
    Re: Canadian rental options
    Farm tank.........heh. "tank farm"
      are you just cutting the pipe then use a gas powered cut off saw
        Thanks but I need something that will keep things a little more precise. I imagine a kung-fu expert might be able to get a percentage of cuts straight enough on a 12" piece of pipe to go immediately to a roll groover.... nobody like that on my crew. But I need it done right the first time each time.
        Regards
        Dave
          Grooving 12" is not an easy task. What sch. are you using, 10 ga I hope.
          Anyway check with your supplier, he may be able to cut and groove for you,
          if you give him the dimensions, or a spool drwg.
