The Disposal Backup
  • The Disposal Backup
    Well I got home to my kitchen sinks full of murky water with food chunks in it. We had had the disposal back up before but this one was stuborn.
    Started by using a plunger. Wouldnt budge. So I took the plug out of the P-trap and sent my trusty quick spin in there to see what it could snag. After about 10 minutes I gave up.
    So the final solution was to take apart the pipe were it entered the soil pipe. I loosened up the sleeve and tried holding a bucket under it. Was a bit tough to slide off and by the time I slide the rubber sleeve off I had loosened up the joint that went verticle to the kitchen drain. So I got 4 gallons of nasty water falling down all over my tool shelves and onto the floor. Not happy at this point.
    So I spend 30 minutes cleaning up the mess and drying my tools off. Luckily I had some solvent cementer so I glued the joint back and put the sleeve back on.
    Turns out the blockage was a whole bunch of ednamame pods I sent down the disposal last night along with everything Helen sent down today. Bigtime fun.
    Anyways.. though I would share my adventure. I like to pretend I am a plumber sometimes.
    Josh
    Re: The Disposal Backup
    call a plumber
      it looks like playing golf with rick paid off
        Looks like the drain diameter reduces downstream, thats a big code no-no as it will cause stoppage problems.
          i was going to say the same thing
          so josh you need to take the pip out of the hub and put in a larger one then pour a new lead joint
            So is grinding edamame pods!
            I love my plumber
            "My Hero"
            Welcome, Phoebe Jacqueline!
              Shoot even I caught onto that one right away.
                yeah.. I figured that was wrong. I didnt install it. I just have to deal with the blockages
                  I figured that, but it can be fixed...
                    Josh
                    Looking for a drain cleaning job are ya??? Your hired
                      Josh
                      what the heck are ednamame pods?
                      must be a veggie
                      why didn't you plug it last week when the crew was in the house
                      your parents didn't teach you their trick
                      ps. take a good photo of that 2 x 1.5'' connection to the cast iron wye. that's the one that needs to be burned out and reconnected with 2''.
                      it can wait til roundup 2009.
                      i called it first. it's my job. adam, ben, bill
                        where was the seasnake micro during all this?
                        especially the diagnostic phase.
                          I dont have a micro at home... only when I intentionally take one home for a job. Plus it wouldnt have made it through the p-trap. I woulda been able to clear the blockage if I had a k-39. Had to do it the old fashion way though.
                            must be a veggie
                            Soybeans Rick,
                            Hey speaking of food...Joey is at a meeting tonight.She told me to check on you.
                            Are you still licking that frozen stroganof block She left for you to heat up?
                            Give me a call and I'll walk you through the micro-wave process.
                              must be a veggie
                              I pointd it out before you, so its mine. I'll fix it in a jiffy. Alright, you can hold the torch Rick.
