Wet Dry Vac Locking Hose Replacement?
  • Wet Dry Vac Locking Hose Replacement?
    I have a 3 gallon Ridgid Max Select Cordless Wet/Dry Vac and I am in need of the 1-7/8" x 7' Expandable Tug-A-Long Locking replacement hose. I am not able to locate this product online or on the shelf. Any suggestions welcome.
    Re: Wet Dry Vac Locking Hose Replacement?
    are you able to remove the ends of the hose without damaging them?
    if you can, then replace the damaged hose with another of the same inside/outside diameter?
