compressor for framing gun
  • compressor for framing gun
    Hi, y'all... looking for a little help and expertise.
    I have a Ridgid Clipped Head Framing Nailer, but no compressor.
    Wondering what size, type, psi, etc., etc. I should look into.
    Only using gun for re-building porch & patio destroyed in hurricane,
    so not looking to frame whole house or anything quite that large.
    Sears has a 3 gallon and a 5 gallon on sale for less than $200.00,
    but not sure if they would / could do the job. Trying to go as cheap
    as possible as the unit probably won't get used much after I finish
    rebuilding porch & patio.
    Any help greatly appreciated. Thanks.
    Re: compressor for framing gun
    I used a 5gal to build my entire house, sharn (too big to be a shed and too small to be a barn) and shrarge (too big for a shed too small to be a garage).
    The only draw back I have found is when I'm doing sub floor or roof decking, I have to give the compressor a break now and then because the constant running gets it a bit hot.
    Sewer main snaking (roto rooting). Sink clogs. Sewer backup. Pipe inspection/locating. No Dig trenchless repair. Root clog removal.We are NOT to replace your local Plumber, as we do not do plumbing. WE ARE YOUR DRAIN CLEANING EXPERTS!!! waterville winslow bangor augusta skowhegan fairfield pittsfield oakland
      Check out both Porter Cable's and Bostich's 6 gallon pancake compressors. We use both on the job and either one will run a framing gun no problem. You can pick up either one for less than $200 as well.
      You only live once, so play with your tool often.
