shift
    Re: shift
    Well, got the valve trains done and hooked up. Tested to 80 lbs. 50% of the valves leak between end cap and body ! Get 25 in the mail today cut them out , unsweat , resolder , test 50 % of those leak. I did find a cap in the pipe.
      Re: shift
      Here's pics of my TIG'd chiller mains. Some of the valve test.
        Re: shift
        Time to switch valve brand, no?
        Where'd that come from?
        Years ago, I traced a flow problem to a 1" 90 with a 3/4" 90 stuck inside of it.
        The 90 was installed during a crawl job, evidently with inadequate lighting.
          Re: shift
          nice to read that your getting work stoke.
          keep up the good work.
          Vince
            Re: shift
            [QUOTE=Plumbus;217437]Time to switch valve brand, no?
            They were willing to send me more replacements I said no. The project manager listened to the voice of reason ended upgetting 30 Nibco SPF 6000 or something like that. Cut them out, unsweated,cleaned, resweated, hooked up, tested to 80lbs. Not even a packing nut leaked. My helper installed the 2nd floor (have to wait for the acid etching and poly coating on the 1st floor to dry) Then retest .
              Re: shift
              All the 2" B. V. c x c leaked. Two 3" also. Owner said pull them all. So, 21 units, 4 valves a piece. 30 or so of which have already been replaced. I will replace and retest.
                Re: shift
                Heating side is done. Plug and play. This was my first Buderus. I would put one in my house. Chilled side is almost complete. Six drums of 50/50 prope, the York guys are coming tomorrow to dial in the chiller. Little bit left on the Lochnivar.
                • #23
                  Re: shift
                  2nd floor cooling.
                  • #24
                    Re: shift
                    Found out that I've got six to pipe over the summer. It 'll be fun. The Burnham's are a total repipe, the green unit's are a replacement.
                    • #25
                      Re: shift
                      Lots of steel on these. 1/4", 3/8", 1/2" plate.
                      • #26
                        Re: shift
                        Beautiful work Stokes.
                        You guys do your own insulation?Or does your company sub it out.Personally I can't stand it.That stuff is 10 times worse to work with than wall insul..
                        • #27
                          Re: shift
                          Adam, It's all farmed out. Thank god.
                          • #28
                            Re: shift
                            Some domestic hot water "arrangement". Both pumps cast iron.
                            • #29
                              Re: shift
                              smore pics. Right 2" is cold feed. After that I lose track. What I didn't show was the switch gear in the back. Pipe run right over the top.
                              • #30
                                Re: shift
                                You do some real nice work. How'd you bend that straight copper pipe so well? Did you anneal it first?
