shift
  • #31
    Re: shift
    You do some real nice work. How'd you bend that straight copper pipe so well? Did you anneal it first?
    I found a bender that will do 1 1/8".
    • #32
      Re: shift
      The challenge: Hang 6" steel.
      Problem: 40 yr. old lath and plaster ceiling on hat channel covered by 2.5" foil backed foam insulation.
      Solution: Longest 5/8" bit I could find, made a 3' set tool, Ridgid Micro to verify shell depth.
      • #33
        Re: shift
        tanks are run by a Lochnivar Armor
        • #34
          Re: shift
          Sweet. Now I KNOW I can't show you any of my hideous pipe & solder work.
          Thanks.
          • #35
            Re: shift
            I could've sworn I saw "SF7" spelled out in copper in that maze.
            So, how do you get that middle tank out when it leaks?
            • #36
              Re: shift
              Good point. Would it have been better to transfer the cold manifold above the the heaters with 3 separate drops?
              • #37
                Re: shift
                Working with the local towns folk has been a joy.
                • #38
                  Re: shift
                  One more week and I'll be hittin' the pavement. I have an interview lined up Tues. in another state.
                  • #39
                    Re: shift
                    Had the tire blow while driving to work on Fri. One more autograph on that P. O. S. Chevy.(I love to hate that P. O. S.)
                    • #40
                      Re: shift
                      This is the worst I've had it.
                      • #41
                        Re: shift
                        I am not sure it was Chevy's fault the tire lost it tread, but I have a Chevy I am not found of either, actually two of them, the one looks a lot worst than your picture, both of them my dad bought,
                        but it is fun when that tread starts flopping around and the vibration is beating the entire truck as well, glad it did not cause you any more damage than it did.
                        I think most of my tread losses are do to Rock bruising, have a loaded truck and hit rocks on the road and it will break cords or create place where the tread will start to separate off the casing of the tire, (where I am there are a lot of dirt or gravel roads)
                        hope there is Greener grass on the other side of that fence you looking over.
                        Good luck,
                        • #42
                          Re: shift
                          Funny thing is, they just had two replaced ! Go figure. That was thee most awkward, contrary work vehicle I've had to work out of. 2" Xheavy for the rack. (i shlt you not)
                          • #43
                            Re: shift
                            I better get off this thing and look for work.
                            • #44
                              Re: shift
                              Lol
                              • #45
                                Re: shift
                                On a recent job interview mid state,I came across this hopper style toilet. I'm sure you'll notice they didn't use seats and flushed with a gate. Landlord said they added hot water in the 70's. Which for me would be a definite plus. I probably could have picked it up real cheap. I opted not to take it. Seems they wouldn't need me for another month or so.
