Lathe steady rest
  • Lathe steady rest
    I just ruined another chair stretcher because the 18 1/4" long wood chatters so much between centers and the detail work is pretty fussy. I need a steady rest but can't find one that will fit. The problem is I have a Steel City mini-lathe and the distance between the lathe bed rails is 1 1/4 inch. The smallest steady rest I have been able to find on-line is for 1 1/2" between rails for a 10" swing like mine.
    Does anyone have any suggestions about where else I might look?
    Thanks,Tom
    Re: Lathe steady rest
    make your own,
    even two non swivel casters wheels will help on a block of the correct thickness clamped on to the bed,
    http://www.hdv.net/tips/Making%20a%20Steady%20Rest.htm
    http://www.oyvind-riise.com/woodturn...odturning.html
    http://azwoodturners.org/SteadyRest.pdf
    http://www.woodprojectsonline.com/st...teady_rest.php
    http://lumberjocks.com/topics/6441
    http://www.taunton.com/finewoodworki...t.aspx?id=5874
    http://www.pennstateind.com/store/LSR2.html
      BHD,
      Thank you for all the resources. Somehow it never occured to me to make one myself. Most of the ones I saw look pretty simple to make.
      Thanks again,
      Tom
        using shearing cuts help to reduce vibrations instead of scraping cuts,
        also take a look at the steady in the link below, and he has good tips, as well,
        very good article, on turn long and lanky items,
        http://www.bigtreetools.com/articles/spindles.html
          I've seen some nice home made rests using 2 or 3 skate wheels.
          Might have been in ShopNotes a few years back. You might
          find it if you do a search on their website. I would look for you but I am very busy at the moment.
