Hole Saw
  • Hole Saw
    Can any one tell me where I might find a 6-1/2 inch hole saw. I need one to make holes in outside walls for installing pellet stove pipes.
    Thanks Brian
    Re: Hole Saw
    Brian, I am planning to do a wood burning stove but I figured on using a jigsaw to make my holes through the exterior wall. The stove pipes I planned to use were single wall from the stove into a insulated through the wall transition to a double walled stainless. I think by tracing the diameter of the pipe on the inner wall and the making a pilot hole through the center to the outside I could do a decent job with a jigsaw. Consider alternatives.
      Re: Hole Saw
      I have done that but log cabins are a little harder. We install pellet stove on the side to fill in as the finish work is a bit slow in the winter here.
      Brian
        Re: Hole Saw
        Greenlee makes some this big. I think they're really for making holes for recessed lighting, but they can handle plywood.
        Check this out.
        http://www.electricsupplyonline.com/...-hole_saws.php
          Re: Hole Saw
          I won't take credit for these suggestions since I read them on another site having to do with this exact problem. First was to drill a 3/4 " pilot hole big enough to allow for a long sawsall blade to finish the hole. Next was to use a 6 1/4/ 6/1/2" self feed bit which you are looking for and use a small chainsaw to plunge out the rough material inside. Could you use a small chainsaw to plunge cut a square opening and then use a filler to seal and flange to finish?
            Re: Hole Saw
            Thanks Brian
            Why do you need a 6 1/2" hole saw? Do you have special code there? We only use 3" and 4" vent pipe here for pellet stoves, and we have a lot of them.
            Mick
