Bypass Insert Program - which way does the float go?
  • Bypass Insert Program - which way does the float go?
    Does the float go cup up or cup down? Should have noted prior to installing the ByPass Insert, but didn't.
    Anyone know which way the float is oriented on the Rigid Wet/Dry Vac. It looks like cup up toward the lid, but wanted to verify.
    Thanks.
    Re: Bypass Insert Program - which way does the float go?
    The following is based on Ridgid WD1246/WD1635
