Conservation Tips
  • Conservation Tips
    Don't use excessive amounts of detergents, bleach or chemicals that may kill the natural bacteria in your septic system.
    Use biodegradable soaps and detergents.
    To prevent excessive watering of your lawn in the summertime, purchase an inexpensive spring-loaded timer which attaches directly to your outside faucet. This will prevent overwatering in case you forget to shut off the sprinkler.
    Water pressure in your home above 60 pounds per square inch is harmful to your plumbing system and will cause excessive water usage. Contact your local water authority to find out what the water pressure is on your street. If it exceeds 60 pounds, consider installing a pressure reducing valve that will limit the water pressure within your home
    Check your water meter during a period of time when no water is being used. Make a note of the meter reading and check it 8 to 10 hours later. If the meter has moved, there is an indication that you may have an undetected water leak, which should be corrected.
    Toilets consume more than 40% of your total water usage. Installation of a new toilet flapper and fill valve will keep your toilet running efficiently.
    Conserve energy by checking the temperature setting on your water heater. It should not be above 120°F or medium setting on older models.
    Replacing an old shower head can save up to 7.5 gallons of water per minute without sacrificing full spray action at low or high water pressures.
    whoso diggeth a pit shall fall threin...
