snow thrower
  • snow thrower
    what is the best longest lasting snow blower?
    i'm in the market for a good one not a 2 stage that only lasts 1 seasion.
    requirements
    our driveway is about 300 feet long and can drift 2 feet in the night.
    the only dumb question is the one that is not asked!
    Re: snow thrower
    Just jack the house up two feet, get a sled and say screw it.
    (I have no idea. Good luck.)
      Re: snow thrower
      The Ariens snowblower is one of good products and I know there is couple other in market are good one as well.
      the 24 or 32 inch unit two stage work for ya and get at least 5 HP the smallest one you can get but normally 8 HP is normal range unless you want to blow it out in the hurry then 10 or 12 HP unit will do the job but cost more than 8 Hp and what more there are few options you can use as it will suit your need.
      I Have moddifed snowblower with 12 HP diesel engine that will cut thru the hevey drift something I can't do that with 10 HP gaz motor without near stall it.
      Merci,Marc
        Re: snow thrower
        In my opinion with the depth of snow and volume given the length of your driveway, a snow blower is not the solution. You should invest in a plow blade and truck, even if the truck is old and just going to used for plowing the snow and not driven on the main roads or registered! i've had my five horsepower 21" two stage Toro for over twenty years, but then again I have a dirway that is only two cars wide by three deep. I also don't let the snow get deeper than six to nine inches before clearing it off so I don't overload the machine. Seriously you need a plow. Not even sure if a plow mounted on a All terrain Vehicle would do the job once you mentioned the two foot drifts!
        That is some heavy snow and it will take a powerful vehicle and blade to more it on any kind of regular basis.
          Re: snow thrower
          Originally posted by frankiarmz View Post
          in my opinion with the depth of snow and volume given the length of your driveway, a snow blower is not the solution. You should invest in a plow blade and truck, even if the truck is old and just going to used for plowing the snow ....................seriously you need a plow. Not even sure if a plow mounted on a all terrain vehicle would do the job once you mentioned the two foot drifts!
          +1
            Re: snow thrower
            what's snow?
            steve
              Re: snow thrower
              +1
              jered, don't you have family in ventura, ca?
              i would load up the van for the season
                Re: snow thrower
                I disagree with both Franki and BD. Plowing is only good if you have lots of room to pile the snow. I have a very long drive and used to use both a plow and a bucket on the tractor. Used to take me over 4 hours--now I have a blower on the tractor and I do it in less than an hour. John Deere, Toro, and Ariens all make good ones. I'm sure there are others, but I am familiar with those.
                  Re: snow thrower
                  +1
                  Brother Rick, I'm on the way!!!
                    Re: snow thrower
                    Source:
                    http://www.plowsunlimited.com/airport.htm
                      Re: snow thrower
                      The best and most reliable snow thrower that I have ever used was to move to Florida.
                        Re: snow thrower
                        I gotta give a +1 to PK's advice also. If you don't have the room to pile the snow up than a plow would be basically a bad choice. There's nothing better than to be trumped by someone with first hand knowledge.
                          Re: snow thrower
                          My driveway was 300' + 500' of road that the town doesn't plow.
                          I did the driveway with a snow blower one day and after quite some time on the last pass KABOOM.
                          Then I got a Curtis plow.Now I crank the heat and tunes and plow away
                            Re: snow thrower
                            Originally posted by stxrus View Post
                            what's snow?
                            steve
                            YOU SUCK!!!
                              Re: snow thrower
                              i've had the 5 hp ones before and they work fine. take an hour or two but only last one season. at $600 a season. i'd rather spring for a one that i can get 5 years out of.
