Average hieght & weight of forum members
  • Average hieght & weight of forum members
    5' 7 3/4" and shrinking. used to be 5' 8".
    175lbs
    Vince
    Re: Average hieght & weight of forum members
    age was 1 thing, now height and weight
    what's next shoe size hand size size
      i'll play along. 6'3 and weigh 290 because of the shoulder injury. My normal weight is 260.
        no wonder you beat me in arm wrestling
          you knew that back then and still wanted the challenge. this is probably the worst shape i've been in for quite some time.
            6'7" 377
              Somebody building a database on us? Oh well, I've shrunk a bit too... used to be 5' 11" and 117 lbs (really!) when I was 20, now I'm 5' 10" and 180 lbs.
                Originally posted by DUNBAR View Post
                6'7" 377
                I bet you got one of them special "Shaq Toilets".
                  I probably need one.
                  I keep it simple; 55 gallon plastic drum buried halfway into the ground with a P235R70 tire for that soft cushion seat. Me Rikey!!
                    Seat bidet hooked to the garden hose, right?
                      Better; fire hose off the hydrant in the front yard. (Mexican food requires full wash)
                        Can someone please pass the Bleach or punch me in the forehead?
                        I have to get this image out of my head.
                        5' 8" 123.4lbs. I finally broke 130 and was weighing in at a fairly consistent 132ish but when I got the sickness I lost it all. I'm guessing it will be at least a year before I break 130 again.
                        Target weight: 135lbs. At the rate I gain I should reach my target around year 2031.
                          6' and 305
                            Wow, what a range! 5'10", 215. Now let's find out who has high blood pressure and/or diabetes. I got high blood pressure, worth having yours checked, wheter you're a heavyweight or lightweight.
                              5'10, 160lbs.
                              Before I started working (June 2006), I was 140.
