Multi Tool Hexes
  • Multi Tool Hexes
    Are there any good Multi-Tools with some Hex Wrenches attached? Knife, needle nose, Hex Wrenches etc.
    I haven't found any but sometimes can't get my Google on.
    Re: Multi Tool Hexes
    Check out the Leatherman SURGE multitool
    Then get the optional bit kit which gives you hex, straight slot, phillips, torx, robertson [sq drive], pozi-drive, and even a jeweler's screwdriver straight slot and phillips.
    Go to www.Ripoffs.com and you can find the better quality belt and clip carrier. It holds the tool, a 5w led flashlight, and has a rear pocket to accommodate the two clips of the above bits.
    I forget the exact model# but they do have a chart. I think I have the CO-145 pouch it's about twenty dollars. I have the steel clip. Their pouches are solid, strong, and made in USA!
    The bits may look thin and flat but they really work and are quite tough.
    Cactus Man
      I have the Leatherman Charge AL with separate bits and I find it very handy.
