don't look down
  • don't look down
    so this was my most daring stunt i did in new zealand a couple of months ago.
    all i can say is the first leap. the video din't work, so i had to go back a few days later and leap faith all over again
    630' in 11 seconds is pretty fast.
    don't adjust your volume as there is none
    http://www.youtube.com/watch?v=17GW1ZqYRv4
    p.s this is coming to vegas at the stratosphere in april
    Re: don't look down
    I've been in faster elevators.
    Hit the silk at terminal velocity then I'll be impressed.
      Re: don't look down
      Hey Rick what's the deal with that pause after you first jumped off? It seemed like they kept you hanging for a bit.
      ________
      Vaporizer affiliate
      Mike
        Re: don't look down
        I believe it is for the shock-value to those sitting in the restaurant below the platform.
          Re: don't look down
          That I think I could do. It's kind of like half bungee jumping. Looks fun and scary.
          Bungee jumping just looks a little too intense and I'm just not that into pi$$ing my pants. I gave that up when I was 14
            Re: don't look down
            Now making the jump having a K-60 cradled under one arm would have been really impressive.
            ----Mike
              Re: don't look down
              You must be out of your mind!! My stomach couldn't watch it till the end
                Re: don't look down
                how fast was it coming down
                  Re: don't look down
                  ----Mike
                  honestly, i wanted to strap my little digital camera to myself and get a better picture with audio, but because you're above the sidewalk and people below, they check you with a metal detector to make sure no coins or jewelry to drop.
                  even their still camera that they take a couple shots with are double strapped to their body that's double safety lined to the platform.
                  by the way, 630' in 11 seconds
                  the way it works is with a decelerator? basically a large winch with multiple layers of cable. the winch drum is attached to an airplane propeller. as the drum free wheels the cable being longer on the outside wraps will spin the prop at a slower rpm, creating wind drag on the winch drum. as the cable gets unwound to lower cable wraps, the rpm on the winch speeds up, more wind drag.
                  at the final 50' or so, the winch has a big taper that gets the cable spinning the drum even faster, thus creating even more rpm's on the prop and this puts you into a stall. unfortunately the first time i jumped, they didn't' t tell me that the cable doesn't stop. i hit the mat with my "full glory"
                  i guess joey was pregnant before the jump
                  don't worry guys, they will have it vegas, 2 weeks after we leave
                  800' above the strip
                    Re: don't look down
                    Don't know what would land first. Me or the $hit that got scared out of me.
                    I would do it. can't say I would not scream like a horrified baby the whole way down
                    Rod
                    http://unclognh.com
                      Re: don't look down
                      First time I heard of anything like this was in the movie Entrapment. Didn't even know it was real.
                      That actually looks more like fun than scary to me. But I'm not on the ledge right now either.
                        Re: don't look down
                        Nooo Thankyewwww!
                        www.ClinkscalesSeptic.com
                          Re: don't look down
                          Having to jump off and hover like that before dropping must have been pretty freaky. My adrenaline kicked in just watching it from my couch!
