Sump pump - Rigid SSP-1000 setting issue
  • Sump pump - Rigid SSP-1000 setting issue
    I installed the SSP-1000 sump pump about 5-6 weeks ago and have been very disappointed with the solid state "watersense" switch. It doesn't seem to have any settings. The 3 foot sump hole fills up to only about 8 inches and the pump kicks in and drains in about 3 seconds. During high rains, this pump cycles every minute. The water sense switch is faced away from water entry.
    How do I set, or modify, the watersense switch to allow a higher depth of water to enter the hole prior to turning on? Your help is greatly appreciated.
