Power Washer Pump Lubricant
  • Power Washer Pump Lubricant
    I accidentally poured 10W 30 Oil into the pumb lubricant. I completely drained the pumb lubricant but I need to know what I should replace it with.
    Re: Power Washer Pump Lubricant
    I use 15W40 in mine, but wait for more posts to confirm.
      HD around here has finally started selling genuine CAT pump oil. Do you have a model with a CAT pump?
        generally SAE 30 non detergent
          What is the consensus? What r u guys using?
            In which pump?
            The AR axials use 80w90, the CAT pumps use ND30.
